Dim3nsioneer 558
Hi Vlad
Welcome to the Ultimaker forum! Can you please tell us, what your other fan settings in the expert settings of Cura are?
Hi Vlad
Looks like your GCode steps up fans with layers.
That's why even if you set manually, once you hit the next layer, your code provides a new fan speed instruction.
I guess it scales up with layers, let me know if it is not the case. Can you print something high ?
I use the same settings, only start cooling after a few layers and progressive ( like after 5 layers, 5% fan speed and increments 5% per layer until 100%).
Hi Vlad
These are my settings right now.
I know you said you haven't changed anything, but are you sure that you didn't accidentally enabled a plugin in cura with an alternate fan setting? It's easy to overlook the fact that you still have a plugin instance with all those settings.
Blizz,
I only have 2 plug-ins but none enabled. See below.
Hello Newbe
Din3nsoneer and Flashp0int ment these adjustments in the Expert Settings (Ctrl+E in Cura).
The Default of these values are different, which causes the fan to increase its power on every layer till the given hight is reached.
The Settings above will switch on the fan to 100% right at the beginning of the print and leave it there.
Blizz 53
