I forgot to mention that a few months ago UM started shipping UM2's with "glass impregnated" teflon instead of normal teflon which can withstand higher temperatures without deforming.
Leon - sorry to hear that you're having ongoing issues... I sent you a PM with some suggestions.
@gr5 and @illuminarti thanks for the help!
Leon- I did suffer from similar problems in the beginning. Here is what I did to get things running:
- I only print ABS. If I switch back and forth between PLA and ABS the nozzle will clog at some point. My guess is that residual PLA is incompatible with the higher ABS temperature. After you have cleaned your nozzle, my suggestion would be to stick to one type of material.
- Innofil ABS prints allot better than UM ABS. To me it seems as if Innofil ABS filament is softer and the feeder wheel has a much better grip on it. My simple conclusion is that the type of material you use matters. My knowledge here is limited (I have so far only printed UM and Innofil), but maybe someone on the forum can give us additional tips on that.
- The extruder has a few design flaws making it susceptible even to tiny variations, it is not very forgiving. I have switched to the glass filled insulator, but I cannot say if this is an improvement. So far I hadn't any problems with it.
- In my opinion a closed chamber is a must for high quality prints.
Yes. I have heard this many times. Especially from ABS to PLA. I use "cold pull" at 130C when I finish with ABS and haven't had any trouble but I have only printed maybe 5 parts with ABS. I mostly print PLA. So I'm not an expert.
I wanted to come by and make a quick update.
The cold end and white spacer have been replaced with the newer models and the nozzle was replaced with a fresh one.
I've been printing frequently for two weeks with only one annoyance (which I'll get to) and I've been able to switch back and forth between PLA and ABS with no issues. So, finally, this printer is living up to its promise.
The annoyance is pretty minor and that is that switching from ABS black to PLA doesn't seem to flush out of the nozzle easily. An hour into a three hour print, about 20 minutes of printing was mixed orange PLA with black ABS. I'm not sure how the black is getting trapped in the system for that long. That' said it's a minor annoyance that's probably solved by using a cold pull before printing.
I've seen the same thing. I think maybe there are tiny particles in the feeder or maybe in the bowden? Or maybe it really is in the nozzle.
gr5 1,967
Have you replace the white isolator? I'll have someone message you with a replacement if you want one. That part seems to be the most common problem with underextrusion but I'm going to guess only 50% of underextrusion issues are caused by that.
The heater and temp sensor only come out if you remove that long skinny screw that hold them in. If you remove that completely they should slide out with almost zero force.
