Thanks for your reply,
So is there no way to improve this surface between the support material and the outer layer?
I have tried slowing the print speed of the outer layer, also changing the heat of the nozzle so that the plastic is extruded at a lower temperature and less likely to droop, along with changing the overlap of the extrusion.
I thought that some of these may improve the quality of the layer.
Any other thoughts on this?
gr5 2,224
Please update what country you live in for your profile settings. Also if you are going to post something - please follow it so you will see the answers as soon as they come in. Not a month later when you remember to go back and check (top right corner click "follow this topic").
There is no easy answer to this. Forks, spoons, knives are particularly challenging. I recommend printing the fork vertical with the tines pointing up. Use lots of brim at the bottom. Lower your XY acceleration from typical of 5000mm/sec/sec to maybe 1000mm/sec/sec to reduce shaking (you can do this after it has been printing for a while - in fact everyone should try this in TUNE menu just to experience the difference - consider lowering JERK from 20 to 5 also). It should work okay vertical. It should stick fine if you use heat and glue and the first layer presses in nicely flat.
Alternatively make some kind of curved mold/jig out of some material that can withstand 100C such as ceramic, wood, glass. Then print the fork flat and when it is done heat it in just-boiled hot water and do the final curvature of the fork on the mold/jig.
Or you can clean up the rough surface on the fork with wet sandpaper. Just put water on regular sand paper. But it's not as good as the other solutions.
