What kind of printer do I need for this?
What's the radius of curvature at the tip of each gear? That's the same as your needed nozzle radius. Measuring roughly with my fingers I'm going to guess 0.1mm.
That would mean you could print it on a UM Original if you bought a 0.2mm diameter nozzle. I'm not sure if it would be strong enough for your needs but probably it would be.
The normal nozzle for the UM Original and UM2 is .4mm.
.2mm nozzles work but they are more likely to clog. But many people have had good success. I don't think you can go any smaller than .2mm.
You could print this part on the b9creator easily but I don't know if the resulting material is strong enough - I have heard that the resin is somewhat brittle:
Or the Form1. You could print this part through shapeways.com also.
for such type of print I think that the suitable printer is one with sls technology, but this type of machines are very expensive
Thank you for your answers, I think i will look for Form1+
IRobertI 516
It's possible to print, but not with a printer such as the Ultimaker.
