Yes, 3.1.2,
That's interesting.... I guess I need to tweak filament diameter instead of adjusting flow... Also, I always use Tweak At Z in pairs, one tweak for the layers, another to set it back to normal, in other words, layer 30 would be 110%, layer 31 would go back to 100% ....SO.... If I go back to "normal" I guess a filament that is using 102% in the UM2 menu, would revert to 100% becasue of Tweak At Z....
Dim3nsioneer 558
Afaik any mcode used in a Ultigcode file will override the UM2 setting. This means it will print with 110% flow from that layer on (and will stay on that value for the layers following the tweak height).
Which version of the plugin are you using? 3.1.2?
