PLA
I get comparable results with a damp paper towel. Clean glass gives more adhesion than you need, most of the time:
Though I still put a bit of glue under any areas that I'm particularly concerned about (such as corners, or support structures or similar detached 'islands' that exist at the start of a print).
that's an impressive print
korneel 176
are you using ABS or PLA?
