Posted · support material is difficult to remove
I have been having issues with removing the support material. I am printing a hollow cylinder type product, but the support material attaches to the piece inside and it becomes very difficult to remove. I have also printed this piece on the side but the support material on the outside also gets stuck...
I am printing in PLA using the high quality print button with support material.
Thank you for reading!
    What material is this? Looks like XT. I had a huge problem removing supports for XT as they seems to fuse with the print and break like plexiglass.
    I would recommend not using raft.
    Play with the infill of the supports. There seems to be so many and consider making your own using MeshMixer or other software.
    If you post a picture of the model (as in, the digital model) it might be easier to give advice as it's a bit hard to see where the model ends and the support starts in those pictures.
    That looks like it could be printed in segments and assembled.
    I figured out the problem... I went to Expert setting and selected 3% fill material. I was able to just pull off the support.
    Thanks again for reading...
