Please add a Pause Print feature to Cura?
jweaver
Posted · Please add a Pause Print feature to Cura?
How do you request a feature?
I just got my printer (Printrand immediatly started using CURA.. And frankly its awsome and I have no wish to try anything else as it does everything that I could ever wish for.
Appart from 1 thing.. Pausing a print?
In my first week, I have wanted/needed to pause the job several times due to tangled filament or to remove a 'blob' from the bed and was surprised that there is no feature to do this.
I understand that this used to exist and it was buggy.. And I know I am not the only person to ask for this.. So I just wanted to start a thread for this, just incase the devs might consider adding this.
I suspect there are technical reasons why this can't be done.. But I just live in hope that someone could find a way to do it.
I look forwards to any thoughts you have, and have my fingers crossed that one day it happens.
Jon
    When I connect to the printer with usb over Octoprint I can still use the built in controls on the UM2 and trigger a print from the menu. I dont know if you can pause from a print triggered from octoprint but I wouldn't see why.
    It should be in the Tune menu.
    Don't think that will work properly for the UM2.
