How far does the small white clamp stick out above the wooden plate? The chamfered hole might be too deep, that way the small white clamp doesn't work well. Could you maybe take a picture of the chamfered bit of your wooden plate?
Example:
The left hole is how it should look, the right one is drilled too deep.
owen 19
Try to clamp something around the Bowden Tube above the wood block and then hold this clamped item down with cable ties while the Bowden tube is pushed into it's place.
Good luck.
