Can't print the collet ( it's got metal teeth inside )
DesignSparkMechanical can import them and export them to STL if i'm not wrong
@shiremog: then i didn't get the piece you are looking for
if you use this trick you can even edit the STEP files in DSM;
http://umforum.ultimaker.com/index.php?/topic/2772-spaceclaim/?p=53816
Have you tried them yet, and if so do they work well?
Yes. They're exactly the same as the original.
Hmm ok should be printable too no?
That would be this one then: https://github.com/Ultimaker/Ultimaker2/tree/master/1069_Tube_Coupling_Collet_%28x2%29
That is made from Nylon according to the documentation, so it should be printable...
I just know I'm going to loose/break a collet, especially while I'm playing with feeders! So I've been looking around for a source of replacement & found these:
http://www.amazon.co.uk/dp/B006PF1RBK/ref=pe_385721_37986871_TE_item
For £5.25 I've got 9 collects. That should keep even me going for a few months :-P
Is the link correct? I get to some
Natures Water 1/4" TEE T PIECE FRIDGE WATER PIPE FITTING PACK OF 3
when I click it...
@reibuehl: If you look closely you can see that there's a collet at each end of the fitting.
And you can't really print it as there are metal teeth inside of the collet that bite into the bowden as shiremog mentioned. It wouldn't have enough grip without them to hold the bowden in place.
@IRobertI: Oh, I totally overlooked that... does that mean that I can also use the matching 1/4" freezer hose as a replacement for the bowden tube? Or is this a different material/strength/dimension?
Well i wasn't aware that these collets had metal teeth... but they do break, one on the french forum broke his while doing the atomic pull
and there not in the spareparts webshop ......
That's why I went looking for them...
Very unlikely to be the same size or material. The bore on the UM is unusually small & the material is not very common.
... well ... if you buy the Bowden Tube, are included one Clamp Clip and one Tube Coupling Collet.
Yes, I know ... 15 € + shipping ... :mellow:
Guglielmo
My way's cheaper. And I get 9 sets!
I came across this stuff. No clue if it lives up to the quality:
Just received a pack of these, they work a treat! Awesome find shiremog :-)
Just received a pack of these, they work a treat! Awesome find shiremog :smile:
Wonder if I could get commission... :grin:
Nah. Probably not, just that nice warm glowing fuzzy feeling you done good ;-)
DidierKlein 729
Or cheaper you print them
https://github.com/Ultimaker/Ultimaker2/tree/master/1071_Clamp_Clip_(x2)
