also very usefull for printing vases and stuff, using larger nozzles is making it even more usefull;
few more links;
http://umforum.ultimaker.com/index.php?/topic/8479-spiralize-overhang-test-xt-on-08-nozzle/
http://umforum.ultimaker.com/index.php?/topic/7488-trick-cura-to-change-print-path/?p=70210
IRobertI 514
"Spiralize the outer contour" in the expert settings.
Do note that if you have your shell thickness set to 0.8mm for example cura will try to create a single wall 0.8mm thick with the 0.4mm nozzle. In other words, it will over extrude heavily to accomplish this. It can work, but you need to slooow down. So it's better to set it to 0.4mm to match your nozzle.
