Nozzle size cant be set lower then 0.1 mm which is still too much for the sheet metal part.
Another approach would be a scale option/tool where you can set minimum thickness in the target model... Does this excist?
Are you sure...?!
The value will be red, but you can set it lower. [i think I did set it to 0.01 to follow the line...]
Other option i still want to try is to start the cura engine command line, then you can do more option [i think] like sprialize with solid top. You can see and hack the "slice engine log" for this...
cheers \ joris
If 0.1mm is too big to print your model then I think you're simply trying to print things that are too small for the printer to handle. What is the thickness of the sheet metal parts you're trying to print?
The value going red is just a warning. Cura will still do it's very best to work with whatever (weird) values you give it.
A "I have no clue what you're trying to do, but I'll do my best" type of warning. But, yes, Cura still tries.
Yes I know I am printing object which the printer can't handle. Smallest thickness is original 1.5mm scale 1:30 gives 0.05. As mentioned I am trying to have Cura print this so I don't need to redesign the original model...
Setting up nozzle size 0.05 seems to work, i will test it and keep you informed.
IRobertI 520
No, you can't mix "normal" printing and spiralize in the same print. It would defeat the purpose of it.
It might be possible to trick cura into printing your thin parts by saying you have a smaller nozzle though.
