The next picture in my gallery is one I took. Just about right. The pink filaments photos were taken I believe by Simon/Illuminarti.
Ok. Tried to get results closer to the pictures mentioned. This filament must be way harder than the UM supplied stuff, because I had to put a nut behind the washer to get enough compression. It also occurs to me that this filament might just not be very good for 3D printing, at least not at high speed.
Currently testing.
Did you measure the filament? Is it actually 3mm diameter? Or 2.9? 3mm filament is not supposed to actually be 3mm. That is the absolute upper limit. Typically it is 2.85 or 2.9mm. Not 3.0mm. If it reaches 3.01mm it will probably clog in the bowden.
It is definitely 3 mm. I have since ordered 2.85 mm from Gizmo Dorks, but I have been trying to finish this spool first. The thought of just throwing it out has repeatedly crossed my mind, but the final prints from it seem to come out perfectly fine, as long as I don't go too fast.
- 1 year later...
much obliged
gr5 2,334
You should increase the tensions on the feeder spring a bit I think. I would expect the teeth markes to be a little deeper.
You should be able to achieve similar print speeds to the UM2 which is about 10mm^3/sec at 230C so at .1 mm layers that would be 250mm/sec. That's kind of the top end. More data in the form of pictures and text here (post #2) which was done before UM2 existed:
http://umforum.ultimaker.com/index.php?/topic/1872-some-calibration-photographs/?p=13194
aviphysics 9
I have read that previously (just after I got the printer.) It was helpful, but it doesn't really cover feeder adjustments.
Do you have any pics if what the filament should look like if the feeder spring is set correctly?
