Cura 14.12 Retraction Settings
area0404
Posted · Cura 14.12 Retraction Settings
As stated in title, I can't find it anywhere. Online sources told me it is here under Machine. Nope.
I found some retraction related settings here. But Retraction Distance is not found.
Please help! :)
    So, no way to modify it through Gcode? That's one thing I've not really like about Ultimaker 2 so far starting out with it. So many things have been "on the machine". Same goes for temperature control. Spent a while looking for that too. :/
    Anyway, in the mean time shall go explore the menu on the Ultimaker 2 more indepth! Thank you!
    If you want to control everything from Cura. That can be done. Set the "GCode flavor" to "RepRap (Sprinter/Marlin)" instead of "UltiGCode". Then you will have all the settings (temperature, retraction, bed temperature) in Cura and the settings from the machine will be overruled.
    Having the settings on the machine is a great advantage.
    You should use the UM2 for what it's good at in my opinion. Since you can tweak them during the print and based on the material it give you more control and less settings to put in the gcode.
    I see your point. But so far, changing temp setting half way through has not been working great for me for some reason. Having a lot of strings during my last run, so I changed temp from 210 to 205 then to 200 on the fly. At first it printed fine, after I left however, it started to under-extrude in a major way. However, currently I'm printing on 200 from the beginning and it seems to be printing just fine.
    I guess I'll test both setting on-machine and from gcode further to see which one I prefer in the end.
    Changing temp on the fly can overshoot sometimes. If you're printing a 210°c and set directly to 200°c it might drop to 195°c before stabilizing. I know it's boring but try to change the temp in small steps 2°c at a time.
    To me it's a big plus to be able to change these settings on the fly
    THAT'S GREAT! TESTING IT OUT! THANK YOU VERY VERY MUCH!
    You're welcome. We know that the prefer way of doing things won't suit everyone, so there are options :-)
    (Also, if you change to RepRap flavor gcode, you can USB print. But stability of that is not guaranteed)
    You're welcome. We know that the prefer way of doing things won't suit everyone, so there are options :smile:
    Went back to UltiGcode flavour for now though. Can't get the starting code running correctly. Hahahahahaha! Will try again when I got the free time with testing out more RepRep. :)
    I made a post about this here: http://zeleskitech.com/2015/01/03/using-octoprint-ultimaker2-gcode/
    Here is the start code needed:
    ;Sliced at: {day} {date} {time}
    ;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
    ;Print time: {print_time}
    ;Filament used: {filament_amount}m {filament_weight}g
    ;Filament cost: {filament_cost}
    G21 ;metric values
    G90 ;absolute positioning
    M82 ;set extruder to absolute mode
    M107 ;start with the fan off
    G28 ;Home all
    G1 F12000 X5 Y10 ;move hotend to front left
    M190 S70 ;add your own bed temperature line
    M109 S245 ;add your own temperature line
    G1 Z15.0 F{travel_speed} ;move the platform down 15mm
    G1 F200 E5 ;extrude 5mm of feed stock FAST
    G1 F50 E15 ;extrude 15mm of feed stock SLOW
    G92 E0 ;zero the extruded length again
    G1 F{travel_speed}
    ;Put printing message on LCD screen
    M117 Printing...
    The blog post explains how to set temps.
    So far printing from OctoPrint on 14.12.1 has been very stable even on large long prints. Very happy with it :)
    Thank you! I'll test it. Hope it works great!
    OctoPrint won't have stability issues. The issues are with USB on the "computer" side, and the Pi does not have this issue.
    Ah ok, I though it was an issue with the interface within the UM itself. Thank you!
