the head just stops where its at. the printer just seems to have stopped all processing of the gcode.
i successfully printed 4 items of the same gcode but no more than 2 in a row without the problem. i have changed the gcode file a few times in cura but still get the same problem occasionally.
i put my printer in an air conditioned room and i didnt have a problem.
its the first time ive used the printer since november. it was cooler back then but now we are in the heat of summer.
ultiarjan 1,222
What exactly is happening when it stops ? does the head stop in mid air ? does it still extrude plastic ? did it happen with different prints (different gcode files)?
I had a few times issues like this when copying gcode files from dropbox to an sd card, probably took out the card to soon or something else went wrong while copying.
