Posted · Cura 15.01 printing time info
I 've installed the V15.0.1
The printing time and the materiel weigth is displaying very bad.
after move the mouse this display disapear and don't go back.
this is the same thing for the information on the bottom left (rotate,scale...)
With the previous V14 all was good.
this on windows 7 with a radeon HD 7800 series.(my graphics drivers are up to date)
bad display like this
Cura15.01
and after moving the mouse no more display
cura 15.01
my C:\Users\xxxx\.cura\15.01\output_log.txt
Listening for engine communications on 49674
Closing down
Closing down
any idea ???
(i have a laptop under windows 7 on all is good with 15.01)
sorry for my poor english,
thanks
    Ok, just looked at all the differences in the code. And I can only think of 1 thing that could be causing this.
    Can someone who has this issue try adding an Ultimaker Original machine to their machine list, select it, restart Cura, and then check if the issue is gone?
    If that's the case, then I'm quite sure where I made the mistake. (Due to the UM2go I had to slightly adjust how the text on the backplate is rendered, and the UMO does not have this text, skipping that rendering step)
    After this, all is OK for the ultimaker original David ;), but if you restart with the um2 profil the bug is always the same.
    Ok, back into full testing phase! I want this issue, and the SD card issue solved ASAP.
    So, this RC should fix both I think:
    http://software.ultimaker.com/Cura_closed_beta/
    It also has some minor UM2 firmware modifications, lowered the material loading speed a bit as it was causing motor stalls for some people.
    thanks,
    I test the rc, this evening.
    i have the ultimaker original +
    I use UMO+ profil in cura not the UM2.
    i verfy this evening and i will post the result.
    ok good, test this tonight with UM2 profil.
    thanks.
    http://software.ulti...ra_closed_beta/
    i just test it, good job it works with the profil ultimate original +.
    the text display is fine.
    thanks
    just one question if i use this version i must reinstall the firmware marlin with this version on my printer ?
    good WE
    Running 15.1 on Windows 7, I do not have the problem
    I have 2 PC the both with W7 and on one 15.0.1 works fine and on the other not :smile:.
    this problem is not systematic on all Windows7 maybe some hardware with windows7 are concerns.
    but this release http://software.ulti...ra_closed_beta/ works on the both
    Firmware installs are never required. Some releases just improve some stuff (but the UMO firmware hasn't changed in a while)
    ok thanks for your works and your response.
    Have a good night.
    All is Ok with the 15.02-RC1 for the bad display.
    Thanks david.
    Great, will roll out that version this week. Also to fix the SD problems.
    15.02-RC1 solved the text blinking or disappearing at all.
    Thank you Daid.
    I just installed the 15-02-RC2 on Win-7-64 and UM0.
    "Find profile from Gcode" does not work for me. Message: only available on files created by Cura version later than 12. My files are created by Cura14-9.
    Bertho
    Bertho
    This is an pretty old change, you need to have an extra tag in the end code (added by default, but not if old settings are imported)
    This due to the fact that the profile data at the end of the GCode was confusing some firmwares (especially the BFB printers)
    Thanks Daid for your fast reply and all your work.
    Bertho
    I still have this problem with 15.02.1. No estimate is rendered. I am using Cura with a 3rd party RepRap style printer (5-nozzle RoVa3D). I recently upgraded from 14.0x.
    I added an Ultimaker Original, selected it, restarted, loaded a model and I do get the estimate shown. If I then select my printer, the text stays and no re-estimate is calculated. If I then quit and restart and load a model with my printer, no estimate is displayed. I only see an estimate with the Ultimaker Original profile.
    Creating a new profile for my printer also displays an estimate.
    Is there a problem with using printer definitions created in Cura 14.0x?
    EDIT: Update, I found that when I set my printer back to 4 nozzles instead of 5, the estimate displays. Only when my printer is set with (the correct number of) 5 nozzles does the estimate text break.
    Note that 5 nozzle support was never tested, so it might be broken.
