What Don said. And if you watch it when it feeds into the extrduder, you can see it pass through the part of bowden tube above the white teflon coupler that has the spring around it. If you see the material pass that part, then it should feed correctly into the hotend. Cutting the point definitely helps.
donmilne 2
Mine did the same when the UM2 was brand new. I'd guess that the filament got hung up on its way into the hotend. It helps to cut a point on the filament rather than a flat end, the point will help the filament find its way. I also give it a bit of a helping push through the feeder!
The "tock tock tock" is the feeder stepper motor failing to push the filament through an obstacle. There may also have been grinding, i.e. a divot ground out of the filament which you'll have to cut away.
