cloakfiend 996
Also just curious, but i seem to be getting jamms after every print now, while before i would just set it off and it would always clear up after a felw layers, its now persistently getting jams, meaning not perfect prints lile i used to get, even printing the same objects as i used to. Also what confuses me are the settings used to print the default objects as it never seems to jam when i print them, but as soon as i try mine, click click click. Very annoying! Even at 0.1 layer height 50mm/s. Raft or not.
Is it time for a nozzle replacement? I have had the printer on printing for about. 3 months straight, almost no breaks apart from recently, and it always seems to clog when its been left alone for some time...
Any ideas would be great. Back in the day when i loaded material or changed it, it would come out of the end after loading, but now it seems i need to move the material a bit forward in order for it to come out to even start the lprint, ive tried all the usual resets and such, but if the robot prints fine, why should mine not.? How can i find what temps and other stuff the default objects print at so i can try and mimic them to see if its my settings that are a problem?
gr5 2,224
For PLA you could try caustic soda. Lots more info here:
