thanks gr5, do you mean with "gradual curve" to change the geometry?
if i understood you right, its a contruction issue, that can't be handeled in a differen't way with a different slicer?
so if i don't want to change the geometry, i can only skip spiralized and find the best layer/top thickness relation, to get a more or less regular transparent surface? hm...thats tricky...
gr5 2,334
There's not much you can do. If you set infill to 0 and top/bottom thickness to 0 and shell to .4mm and skip spiralize you will get almost what you get now - a .4mm shell with no top or bottom.
But if you set top thickness to even just .1mm you will get "shelves on many of the sloped layers (top 2/3 of your part) to support the layer above - this will show through to the outside and change the look. Really the only thing you can do is a gradual curve to close the top very very gradually combined possibly with thinner layers so the steps aren't too obvious at the top.
