yellowshark 153
Thanks for that George, nice to know someone else’s brain is frazzled :-P . Ok pretty much spot on, a couple of clarifications.
Photo 1) 95% sure that was of version printed at .8mm nozzle real and in Cura
Photo 2) I did two more prints, just a few layers with a 1.2mm wall and a 1.6 mm wall, to check.
The 1.2mm setting produces one 1.2mm pass – it measures 1.35mm but given the few layers printed and I ripped it off the bed so it is bent, that measurement may not be too accurate.
Yes the idea of single pass versus double pass did go through my mind although not as analytically as went through yours. Certainly the fans were on 100% once the slope started. The first pass will be partially seated on the previous layer, I assume, which will be cooled because of the 20% infill work before starting the next layer. Again I assume, that the 2nd pass adheres to the side of the first pass, or not!
The very first run I did was 0.4mm with 1.2mm wall, using supports added by Meshmixer. The surface on that came out well also, but breaking off the supports just left me with too much work in filing down the break points to get a smooth finish ready for painting.
I am thinking now that maybe the way to get really well finished overhangs is to go with a single pass. I have some pieces I did a year ago where I struggled to get a decent finish on the overhang (I have always used at least double pass walls) and I think I will revisit them with this new theory :cool:
gr5 1,871
Woah - I think you just blew my mind! :eek:
Let me summarize as you tried to be very exacting but want to be sure. There are 4 photos in your post:
photo 1) .4mm nozzle (real) .4mm nozzle (cura) 1.2mm wall (green)
photo 2) .8mm nozzle (real) .8mm nozzle (cura) 1.2mm wall (green) (Is this 2 0.6 passes? Or one 1.2mm pass? I'd have to check the code in cura)
photo 3) .8mm nozzle (real) .8mm nozzle (cura) 1.6mm wall (gray) UGLY
photo 4) .8mm nozzle (real) .8mm nozzle (cura) 1.2mm wall (same settings as photo2 but with gray filament)
Is that all correct? Could you double check?
If that's all true then the lesson perhaps is: if you print with really thick layers (.3) and fat traces (.8) it takes longer to cool and overhangs look crappy and this is more important than getting the wall width a multiple of nozzle width.
