Could you be removing the SD card too soon? Before everything is written? Or maybe it is a defective SD card?
It sounds like you need to inspect the file on the SD card after saving it.
It is neither of those, because I make sure to write the file to the hard drive first. The fact that Cura writes the same incomplete file twice confirms this idea, as a troublesome hard drive would not be expected to fail in the same consistent manner. Not only that, but you would also expect other obvious problems.
I have started inspecting every file I print, but I would rather solve the problem than mitigate it. As I did not get to printing today, I cannot say whether the new version does the same.
The ball is probably in my court now, but if anyone has any other ideas on what might cause this they are welcome
gr5 1,968
