Does the UM2 use this one?
http://www.meanwell.com/webapp/product/search.aspx?prod=gs220
Definitely not cheap.
If that is the correct PS, from the datasheet, it uses the 4 pin version of these:
http://www.mouser.com/ds/2/222/KPPX-365228.pdf
Considering that a new one will probably be at least 120 euro, might be worth trying to replace the connector.
I bough mine from mouser. But mine was 280W. Was 90€ with delivery from mouser (they paid the customs. Mine had another connector but I did a cut / soldering and it's working flawlessly
I took the pliers and carefully reshaped the metal parts. Works somehow for now. Propably easiest way is to change the connector. It should be available as a spare part, though.
Ilkka
Do any body have the Electrical pin out mine was totaly torn and i dont Know the wire configuration
On the power supply there is a picture of the connector and answers this question for you.
On the right side of this photo is 24V.
On the left side is ground.
Blue and red are 24V. white and black are ground. It's okay to get black and white backwards as they are the same. It's okay to get red and blue backwards as they are the same.
gr5 1,969
They are quite expensive. Just google the part number written on the supply. I bought an extra power supply myself.
