How many hours did you print all in all until this started? I had similar under extrusion when my PTFE coupler was "used up". The effect was that the feeder couldn't push the filament anymore to the heating zone because the PTFE coupler had lost its stability and was bulging into the filament path under the pressure of the hot end spring. Depending on the temperature you print, this can happen after a few 100 hours already.
Dim3nsioneer 556
If you've chosen a small layer height (below .1mm), try to print with increase layer height.
A few cold pulls / atomic cleanings might also not hurt.
