Marvin - Show us yours?
neo-ninja
Posted · Marvin - Show us yours?
Hi guys,
Back again, I decided last night to try and get a perfect Marvin robot (the one from 3d hubs) but am having some real issues, and its making me question all the little changes etc.. I have done so far.
I printed the below, the left Marvin was printed on basic normal settings in cura on my UM2 straight out the box pretty much. The rihght is me printing it (after spending quite some timelevelling the bed etc.. and also doing bespoke settings listed below:
Layer Height 0.1
Shell thickness 0.8
Fill
bottom thickness 0.6
Fill density 50
Print speed 25
Quality
initial layer 0.1
Cooling fans set to 100% after first 3 layers.
I then printed this with normal PLA at 60c bed and 190c Nozzle
Take a look
http://imgur.com/a/AjBxc
The Marvin on normal takes around 20 mins to print, my settings took it about 43 mins.
TBH im pretty depressed right now - I thought I was getting somewhere over this last week learning about settings etc..
There are a few random questions I have, like should I be printing slower? Why does the right ear look so much worse. Should I put down the temp again? What is going on with the back?
    The marvin is not an easy print :)
    And the blue PLA you receive with the printer is not the best filament too.
    You settings seem good to me, what i would do is reduce the infill (no need for 50%) you can reduce to 20% or something like that (i'm not sure but it can maybe be printed without infill?
    Except that you can maybe print two at once to let it cool better and position the marvins so that the right fan cools the one that's not being printed?
    The right ear looks bad because it's not cooled well (the right fan is too far from the print).
    So actually the 50% fill was because I read on the 3dHubs site that it helped with some of the the form.
    I have seen that people on 3d hubs have done a perfect print with it on UM2s and certainly alot better then mine.
    Other then printing two is there any other suggestions?
    Try this : https://www.3dhubs.com/talk/thread/my-first-marvin?user=54644&timestamp=1426237694&otl-token=kZ2vbjIHF60RS021jD9xSma56li-0NeE0vb7cAywXG4&utm_medium=email&utm_source=transactional&utm_campaign=drupal_transactional
    It says:
    Layer Height: 0.1mm
    Shell Thickness: 0.4mm
    Retraction: enabled
    Bottom/Top Thickness: 0.6mm
    Fill: 0%
    Print Speed: 20mm/s
    Temp: 210C
    Bed Temp: 70C
    Filament Dia: 2.85
    Flow: 100%
    No Support or Adhesion
    I also enabled combing and set the z-hop at 0.075
    Oh interesting that looks great. I will give it a go tonight and see what happens.
    Should fill actually make any difference though?
    if the part just needs to look good and you don't have a huge top gap to fill the infill isn't needed it can even make problems with some settings
    Ah ok, thats interesting.
    So it looks like you also made the shell much thinner, any reason why you would do that?
    i also just read it there and tested it and it worked better then my earlier results but it seems that some 0.8 shells also work well and i didn't tested this marvins a lot yet
    Are you sure you are really printing at 25? Did you set 25 in the advanced tab of cura, or did you just set 25 in the basic settings speed (which will do nothing). Those overhangs in the lower part of the body are really nasty and they don't look printed at a speed of 25.
    As advised above I print Marvin as a twin.
    I found the best orientation was with them each facing a fan i.e. built back to back facing left and right across the bed. This helps the air to flow between the legs as well as onto the faces, for the eye slots and top hat ridge.
    Also position them with enough gap between for the fans to work on one while its twin is being made. This also helps to cool the top loops.
    Ah when you say the advanced tab setting? Which setting in there should I be changing? I only changed on basic tab
        • 31 replies
        • 24 replies
