Nallath, you are right. I have tested the speed test cylinder and fails above 3mm3/s. I am using robert's feeder and apparently it works well, no skipping. Have performed two atomic cleanings and have tried three different spools. I have been using Roberts feeder for some weeks with success, until today.
Is there anything else to look for?
nallath 1,119
Could you add a photo? This really helps with 'debugging' the problem.
Judging from your description I believe it could be http://d33v4339jhl8k0.cloudfront.net/docs/assets/53970867e4b0c76107b1091a/images/53bbf859e4b09d13bf3cdd85/file-NJOw1Ah4bz.jpg
This is caused by under extrusion. You can find quite a bit of topics that deal with solving that problem.
