How did you go about changing the plastic? You say that your spool was stuck?
Did you change material profiles to ABS so that the printer is using the correct temperature?
"Its weird because the plastic exitted the head and when i try to print, nothing comes out of the nozzle." - I'm confused, you say that plastic is coming out of the head but nothing comes out of the nozzle?
You see that the plastic is moving into the printer as well but not plastic is coming out? That's just not possible, it either moves or it doesn't. Is the feeder grinding your plastic?
When you loaded your ABS you say you saw a tiny amount of plastic coming out. Are you sure it was actually plastic being pushed out, or was it old plastic simply dripping out?
Sorry, but your post is a bit confusing since it's contradicting itself a bit.
neotko 1,417
Well that would happen on practicaly any fdm printer. When changing from x material to y (being different plastics) the atomic it's just a must. Also check filament sizes (anything bigger than 3mm will stuck since ultimaker uses 2.85mm filament).
Edit. The Pla literally burns at 240C and goes brown (it's sugar based). The traces of PLA that stay on the nozzle will burn and go brown at ABS temperature (but you can use 240C for pla if you print at very high speeds but it's not recommended). The think that propably jam your brand new nozzle was that. If you go from any material to other kind, sometimes even changing brands, the best think to do always it's atomic pulls.
There's also some cleaning filaments that can be used to 'capture' any residue and leave a clean nozzle, but they are expensive compared to a simple atomic pull.
For my cleanings if I use my 3mm extruder (2.85 filament) I just use a ptfe 3mm and push it though, then lower the heat and pull to get all. This way I don't waste filament.
Edited by GuestLink to post
Sammael 1
Thank you for the fast response! I'm gonna try the atomic method as soon as i get home i'll post feedback here
