gr5 is right; it's probably a loose connection somewhere on the print head. Fluctuations in readings are the first warning, typically. I've had to correct loose connections several time overs the 2-1/2+ years I've had a UMO. I found that the black strain relief clip only increases the frequency of the wires breaking near the clip inside the insulation (where the broken wire is not visible). Having a large free loop in the white connector wires to the tie point well up the Bowden tube reduces the problem to a very low frequency of occurrence. I found a large supply of the crimp-on pins for the white connector housings and they should NOT be soldered to the wires (the factory soldered them on my UMO). The ridged solder creates a stress point right at the pin. Crimp connectors on multi strand wire are the way to go! Most recently, a TC wire loosened right at the green PCB connector.
I've had numerous electrical problems with my UMO (really the only problems after initially sorting our the initial build bugs) and I still have one gremlin that I'll probably never successfully debug. I spent a great deal of time debugging and reworking my Ulticontroller board. It was so unreliable until I manage to correct all the problems from a sloppy assembly, I soldered-in a socket for my LCD display so I could remove the LCD assembly from the base board easily.
Hopefully the new and more expensive electronics in the newer models is of higher quality that what shipped with my UMO.
gr5 2,094
Does it only happen when the head is moving? Or does it happen if you just set it to 180C and sit around and watch?
I guess I would certainly poke all the wires. The thermocouple itself is incredibly simple and it is hard to believe that's the problem if you took it apart and inspected it.
The output of the small board on top of the head is supposed to output 0V for 0C and 5V for 500C and so on in between linearly (there's some magic chip that does this). It seems unlikely the chip is bad but I'd measure the output voltage of that chip while watching the Ulticontroller display at the same time to isolate the fault. Also check that the power going to that little board is steady at 5V.
There's a spare set of wires running from the top of the print head to the PCB underneath. Consider just switching over (both ends of course) to the other cable. It might fix all problems - it did for me. Also there is a green connector where the thermocouple wires go in - those screws somehow got loose on me and I had to retighten those once.
aviphysics 9
I think it used to happen only when the head was moving. Now it happens with the head just sitting there. The problem has been slowly getting progressively worse for a while, until today when it seems to have completely failed.
I will have to try your test later. With the thing not working, I decided to take off the hot end and finally give the UBIS a try. The UBIS is working really great. I setup the UBIS to run on the same cables that the stock hotend did, so it seems like they aren't the problem.
As a side bonus, it seems like this was also probably the source of my stringing issues. I am guessing that the hot end was probably running way too hot, due to the malfunctioning sensor. I had previously noticed buldging in the last 30 mm of filament, when I removed it from the hot end (which had also been getting progressively worse), which I am guessing might mean the stock hot end is somewhat wrecked.
Edited by GuestLink to post
