Are you talking about a white ring part? It fills in the small metal gap between the nozzle and the metal fan shroud - remove the 4 screws on the shroud, put in the hole from above, then put the shroud back on over the nozzle and put the 4 screws back in.
Or do you mean the 3dsolex i2k isolator black ring? That goes below the white teflon isolator - you have to take the head completely apart for that.
Or is there a new thing?
Thanks for your reply. I'm talking about the small white ring called "PTFE Coupler ring" which you can see is a part of the hot end pack now:
https://shop.ultimaker.com/product/61/Hot-end-pack
Someone at Ultimaker said it was only implemented a couple of weeks ago...
gr5 2,243
