Posted · Ventilation Equipment for Ultimaker 2
I am beginning to set up a makerspace in the university library where I work. The space will have two Ultimaker 2 3D printers. Unfortunately, the space we will be using is small and poorly ventilated. After looking through the Ultimaker support pages, I found a page on safety and compliance that recommends the use of a fume hood with active carbon filtering. Could anyone recommend a model of fume hood that has been used successfully in a small makerspace? Otherwise, does anyone have any suggestions of alternative ventilation options or equipment? I plan on stocking the space with PLA plastics, but I would prefer to be prepared with proper ventilation in case ABS plastics make their way into the makerspace.
Thank you! Any ventilation suggestions are appreciated!
    I don't think you need any ventilation if you have less than 10 printers. 10 printers printing PLA non-stop will make less aromatic hydrocarbons than frying one hamburger every 3 hours. That's an estimate. ABS is much worse but even ABS is not too bad. I think you should try it first and decide later if you really think it needs venting or filtering. I suspect you will conclude it's fine without even if the printers are used non-stop. Let us know (how big is the space anyway?).
    • 2 months later...
    Hello,
    I will get a little bit out of topic here.
    We are building a stand for our Ultimaker 2 at office, mostly to keep it safe from dust, since here that is a serious issue.
    My doubt is about the need of ventilation during the printing process. We designed a case that is about 600mm by 530mm by 530mm (h/w/d) made out of acrylic and plywood. The idea is to always keep the printer inside it, even while printing. Do I need to provide any ventilation system for when its printing? I didn't want to keep any ventilation slits because of the dust, but I worry that the heating of the printer might be an issue.
    Posted (edited) · Ventilation Equipment for Ultimaker 2
    Hi there,
    I'm in no way an expert and could be wrong, but I would go towards some ventilation though. Maybe a ventilation system with micro holes that keeps away most dust?
    Electrical cabinets at work have fans with dust filters on them.
    [media-thumb=5748][/media-thumb]
    You wont want all the electronics getting hot. there can be problems if the stepper motors get hot 2.
    Good for printing abs though.
    Thanks! We ended up installing vent hoods (like one would use above a kitchen stove) with carbon filters above each 3D printer and have only been using PLA plastics. These seem to be working pretty well.
    *Update (8/17) We've also added a tower HEPA type air purifier to the room, just to be safe.
