I have recently started to use the kapton tape on the bed as I was having some difficulties with ABS adhesion, now prints are sticking perfectly, both ABS and PLA! (had to dry the abs in the oven too)
I haven't used the pause at height feature before so this will be an interesting experiment for me. Hopefully I will have some free print time over the weekend to test this out.
In my head I can see this idea working brilliantly, but I would be surprised if I was the first person to try it!
gr5 1,872
You could probably use pause-at-height. This is very intriguing. I hope you try it and let us know. Try it with something that only takes 15 minute to print - maybe an upside down "L". Support the overhang but then add capton tape. Make the vertical arm of the L only 5mm so you don't have to wait long before adding the tape. Tolerances will be very tight - but the UM2 can handle that if you experiment. I think this could work. Not sure. Normally you want the kapton tape heated to 45C or so. I haven't used Kapton tape in years and I don't remember if PLA sticks to it without the heat - I think not. A hair dryer could heat it up enough for the PLA to stick.
