I think you have 2 options, ofc making a plugging would rock.
- Simplify3D has Z offset (150€ slicer no demo to test)
- Attach something of 1.3mm to the piece that hits the Z sensor (design + print). On umo the wood would let you screw something to it probably, on um2 I think it's a screw that hits the sensor on the lower part, so that could be trickier since you need to remove distance. Maybe unscrew it 1.3mm?
Droping ideas
nallath 1,125
Cura has no such feature. It only has very limited uses cases and makes the workflow much more complicated / confusing. With a little bit of g-code tweaking you could implement this yourself (Do a certain move before you start and reset the zero position).
If you want to make that automatic and know a bit of code, you could use https://github.com/nallath/PostProcessingPlugin
