X Y axis are not perpendicular
Posted · X Y axis are not perpendicular
I have a new UM2, about a month old, and finally I managed to calibrate it well enough that I get really nice prints.
The problem is that the X and Y axis are not perfectly perpendicular to one another.
Instead of a square I get Parallelogram shaped parts. it's very light so it's hard to see, but when you put it in a CNC frame it won't fit.
Here you can see that the 2 parts perfectly fit when they are orientated the same as they were printed.
Both X axis are in the same direction and the Y.
Here you can see the perpendicularity problem if I rotate one of the parts 90 degrees.
So I don't have 90 degrees and I get parts that are like this:
What can I do?
Please help.
    I usually square things up by doing the following:
    • Move the head to the front center, all the way towards you
    • Look at the distance between the right sliding block and the closest pulley, compare this distance to the left one.
    • If they do not match, loosen the pulleys on one side so that that sliding block can be moved without affecting the other.
    • Adjust the distance so that it matches the other block.
    • Re-tighten the set screws, and tighten them very very well
    • Repeat if necessary and then move on to the other sliding blocks
    What I don't like about those tools is that they're like USB ports. No matter which way you turn them, one screw is always out of reach. That's why I like doing it by eye. Then again, I have a few years of experience so that helps I guess.
    raz - please pick the "best reply" and mark it as so.
