tinkergnome 926
Anyway I guess I will have to order some XT.
At least i can confirm that Colorfabb XT (black) was able to survive the last summer without any deformation or visible degration. Continuous outdoors and exposed to the sun since April (and the summer was fairly hot in Europe this year...)
I recommend to give it a try...
BrayChristopher 36
I emailed Ultimaker support and their response was:
"I checked in with Ultimaker's materials specialist and he does not recommend CPE for extensive outdoors use. He says that it is fairly UV sensitive.
I've attached the MSDS sheets for ABS and PLA. It looks like ABS specifically should not be exposed to sunlight for long periods, so you may have better luck with PLA. PLA is more sensitive to temperature than ABS is, but it looks like it may be less UV reactive."
I don't know how to attach PDF's.
