Looks like a z scar move even though it's on spiralize.
well it's not easy to see in the video- its in sec.11-12.
the the nozzle is moving a step back and you can also hear it, this happens not regular, what is also shown in the photo.
i turned spiralized on, because i didn't wanted a z scar , and thats why my wall thickness is not 0.8 (with 0.4 wall thickness the wall is too translucent) i am trying to find another video, but its difficult to capture...
ahh, I saw it now, thanks. What version of Cura are you using?
Edited by Guesthere is another one
its cura 15.04.2.but the problem was also there with earlier versions (problem is persistent since a few month i guess since 15.04 ?).
Edited by GuestThere's a TON of discussion about this on the forums somewhere. It's a relatively recent bug but it appeared before the latest rewrite of Cura. I'm not sure how far back you have to go to get before this bug but I think about a year. Try Cura 14.6.* or older (14=2014, 6 would be for example june). Cura has been working quite well for quite a while so these older versions are quite mature and safe and stable.
thanks gr5 for the explanation of cura versions and infos! i will go back to 14.7(?), from were i started with this project.
is there a chance, that this bug is getting fixed in the future? would be great !!!
I lost track of it. The developers of the new cura Engine I believe were discussing it so I think they are aware and it might be fixed in the latest version (15.6 or newer) I really don't know - but I certainly saw lots of discussion about this - I think it was in the spring.
SandervG 1,499
Hi Imke,
Thank you for your email.
I don't see any odd behaviour in the video, do you have some examples to show your issue a little bit better?
What do you mean by backsteps?
You should keep your walls in a multitude of your nozzle, so make it: 0.4 or 0.8 or 1.2 instead of 0.5
Looking forward hearing from you!
