It's really hard to see in the picture, but to me it actually looks fine?
What I'll often do is to simply babysit the first layer, turning the leveling screws as the printer is printing... Typically I'll use 2-3 lines of skirt as well, so once the printer starts to print the actual model, the bed is leveled nicely all around... That of course only works if the bed is actually plain... If not you would have to compensate constantly while the printhead moves around on the first few layers... After that, you should be fine even if it is a bit uneven (after some layers the unevenness will flatten out).. Not really an optimal solution though.
janet-t 3
The main issue is on the front left side, mention that the photo is taken from the back of the printer.
