DidierKlein 729
@Labern has a good point with the heater cartridge, maybe the stock 25w one is not suited to go so high in temp or at least it will take much time to reach higher temps.
The error is triggered if the heater cannot heat a certain amount in a certain time (this depends of the firmware version).
Labern 772
I fails when it can't reach the desired temp within a certain time. Different firmware versions have different times in which it alarms. You could try an older version of firmware I think pre 15.0 (can't remember the exact version it was implemented)
Otherwise you could change the heater cartrage to one with a higher wattage so it will heat faster.
