Hi, I've had this problem, a couple of times. I think I actually have is fixed now. Turn everything off and raise and lower your bed manually. Make sure you bring it up to the nozzle. When you lower it, if you notice that it sticks, place your print on the table and compare if it sticks at the same height as your missing layer. If so, your going to have to get some lube and take some stuff a part. Check the rod to see if there's anything on them that may cause it to stick.
Take the bearing covers off and tape it to the top. Next take the tread rod nut and unscrew it and then rotate it to the top. Make sure this doesn't stick as well. Now you should be able to freely move the table up and down just on the bearings. Try lubing (Use sewing oil, but I ended up using car bearing grease) to lube the rails and move the bearings up and down until smooth. If that doesn't work, you'll have to find the sticking bearing by removing the screws from them and moving them up and down the rail to see if one sticks and the other doesn't. Just remember when putting everything back together that as use tighten the bearings you move them up and down the rods and that they move freely, no binding.
Labern 772
Have you looked at your model in X-ray mode in cura to see if anything shows in red?
Also Layer view might show something.
you may need to clean and grease you Z axis screw.
