Looks like your drivebolt is a bit dirty, there seems to be filament in between the teeth.
Sounds like there is stress on a certain part.
My first guess is your filament is grinding against something, or your wheel/bearing can't move freely.
Good luck!
Did it run successfully so far?
Hey Sander
Yep it's running great the past few days.
Except for the weird noise...
With "drive bolt" do you mean the knurled wheel of what exactly do you mean?
thanks
SandervG 1,499
Good luck!
