Posted (edited) · SOLVED UM2 PID Autotune failed
I am trying to run PID Autotune on my UM2 but it fails every time. What I am doing wrong? (using Printrun/Pronterface) to send GCode, firmware version: 15.04.2):
M303 S50
Output:
PID Autotune start
PID Autotune failed! Temperature too high
It doesn't matter which values I try - it fails every time. These are a few combinations:
M303 S100 C3
M303 S200
M303 S150 C8
When I connect to the UM2 it correctly displays the actual PID values:
echo:PID settings:
echo:   M301 P10.00 I2.50 D100.00
    Alright, to answer my own question - it seems those values were pretty out of whack. I installed a 35W heater and it heated up too fast and tripped some kind of overheat protection. To solve the issue I first set the PID to 0:
    M301 P0.00 I0.00 D0.00
    And then ran PID Autotune again:
    M303 S150
    This gave me these values - here is the difference:
    Old:
    New:
    M301 P12.58 I1.90 D20.86
    When finished I stored the parameters in EEPROM. Careful with this since everything that was changed will be saved - so don't fiddle with anything else while PID Autotuning!
    M500
    • Like 5
    • 2 weeks later...
    • 2 months later...
    Posted · SOLVED UM2 PID Autotune failed
    Here is an update. After installing the Extrusion Upgrade Kit I am unable to perform the PID-Autotune anymore. It aborts again with temp. too high - even if I set PID to 0...
    I think there are a few things that will make it abort. I think if it trips past the max temp that might do it. For example I think by default the max dial temp in menu is 260 and the max temp is always 15C hotter so 275. If during PID autotune it goes above 275 it will probably fail.
    So maybe try autotuning at a lower temp - for example 200C? What temp did you autotune at? I hope not 150C like you did before. Ideally you want to autotune to a temp roughly close to where you will be using it (e.g. 190C to 250C).
    Or you can use the default values that come with the plus (which is a 35W heater) or you can take the 25W heater values and multiple by 25/35.
    The default PID values are 10,2.5,100 for the 25W heater. For 35W heater you might try 7.5, 1.8, 75. Or use the values you came up with your PID tuning earlier (12.58,1.9,20.86) although that was done at 150C. :(
    I tried auto tune at 150, 200 and 210. And it aborted every time. So it must be something else. I did take the values that came with the +. On my printer these are:
    M301 P10.03 I1.50 D70.00
    Try something like P12.0 I0.8 D70.00.
    If you use the um2+ heater the pid from that should work.
    At what point fails? When the hotend fans kick in or at some point of temp or just you send the command and fails instantly?
    Unfortunately not with my UM2+ upgrade. Heavy overshooting (+15°C) and impossible to autotune.
    And that's normal?
    I don't know ;)
    But it looks like there're quite a some people with problems out here. For me the game changer was a drastically lower I value (huge damping).
    P it's how fast goes up, I the force to compensate the ip/downs and D makes the heat more stable. I did some manual PID adjustment on my third umo+ and I had to lower some values before tunning the autotune until I got a perfect value. But never got a 15C error not even with umo not plus 18V heater (that heats faster than any umo+ heater)
    Well I did set P, I and D to 0 first and it still aborts. It does so while the temp rises well over the target temperature.
    Try setting the default value and lowering P by half or something like that? I barely understand the pid stuff
    This it's the only way I got some pid idea of what it does.
    • Like 2
    Same here, the only way to find the values I posted was playing around with PID settings via printrun during a print. With P12.0 I0.8 D70.00 overshooting now is within +/- 2 °C.
    Nice. The problem is there is a time delay between when the power to the heater changes and when the temperature changes. And some noise. Normally D can dampen any oscillation but because of the delay and the noise sometimes D just can't do it and you have to reduce P and I. Either P or I can cause oscillations. Higher values are more likely to cause larger oscillations. P tends to create faster oscillations (guessing < 10 seconds) and I tends to create slower oscillations (guessing > 5 seconds).
    I'm using this for dual extrusion prints. So it's kinda optimized for the hotends switching between printing temp and idle temp with usually 20°C to 40°C difference. However the settings are not perfect if you want to cool down to a certain temp. If I set target temp to 90°C for an atomic pull the heater will start to kick in at 105°C. I have to lower to 80°C to reach 90° quickly.
    Today installed my um2 hotend china with some stuff bought to 3dsolex (heater and 1.75 olsson, steel coupler tfm coupler) and parts to ultimaker (bottom aluminium & fans). And did some lucky PID using the values of other printer with a by ear calibration. Seems pretty stable at 210C so far just launched first print P12.86 I 1.84 D88.42
    Well my um2+ hotend after a lot of fine tunning because a bad coupler and I saw that the heater fails to stays 'put' but my other um2 hotend with a 35w heater from 3dsolex it's spot-on with the PID that comes with um2+... So I run into the PID overshoot think.
    I did this to run the PID.
    Set hotend manually to 200 until it almost become stable. Then I did run PID M303 E0 S210 C15 since internally PID 'kicks-in' when near 10C. It suddenly overshoot to 223-226 to the target temp, but also it didn't return the PID overshoot error.
    I got: (edited)
    Kp: 8.01
    Ki: 0.48
    Kd: 33.33
    Also tried setting the temp to the target temp manually (220C) and running the PID to 220 this time, I got almost the same numbers again:
    Kp: 7.92
    Ki: 0.47
    Kd: 33.08
    After many months of watching the heater never able to really stay 'put' I decided to debug the source of the issue. Because, even with a new PID the temp never did stay put. And it had sudden jumps of 2-3C in mid-print (with fans off).
    So..
    This it's what I did debug:
    Blue coloring on this kind of metals it's because the exposure to very hit temps. I do turn off the heat as soon it goes red on the blue-ish spot.
    The heater goes red in a matter of just secs when 'on' and also the heat focuses on a very small area that also it's quite far from the tip.
    My theory it's this:
    The Problem I see on this overshooting heater: I'm willing to bet 2 beers that the Nicolinux heater has the same problem)
    - The heat it’s build on a very far position, not uniform along the heater.
    - The heat sensor feels a overshoot of heat that tries to make it stable.
    - Heat suddenly raises on the heater
    - PID tries to make it stable
    - Heater, because has a very small red-hot area, can’t fully do ‘slow heat’.
    In the end, you get ok readings, but you actually ain’t reading the full block heat, because it’s so focused on a point far from the filament and the heat isn't spread along the heater (the point of origin at least). So, you get real temperature fluctuations on the nozzle, and accurate readings of what the heater it’s doing, but not the full block.
    So yesterday installed a new heater to replace this one from the um2+ hotend and it works perfectly with the Um2+ original PID. Also it overshoots at first maybe 10C, but it goes stable very fast and stays there.
    Before changing the heater that's how my hotend did react:
    Set temp to 230
    Reaches 246C and starts going down.
    Get’s near 230 for some time, starts to print
    Temp keeps going down to 223-ish
    Temp goes up again to 234
    Temp goes down to 228
    And after some time it does stay on the target, but also it has sudden weird 2-3C heat loss.
    So, anyone with this Weird PID can check their heater to see if it actually looks like mine did?
    This same problem can happen if the temp sensor is very loose (air gap around it). Basically it's much harder for the PID to control if there is a long delay between when it changes power to the heater and when it measures a change. Increasing "D" value helps but if you increase it too much you can get a different oscillation (there's, I think, 3 ways to get oscillations).
    I went on the route when doing test and tested by applying copper grease (the one for the bed screws) to increase the contact area. It didn't improve this effect. The last test I did about the sensor (apart of using 2 different pt100 from umo+ and e3d) I also tested with a brand new olsson. That's when I started to focus my tests on the heater itself. Replacing it fixed the issue immediately.
