Hey Sander,
Thanks for your response.
We are using the standard 0.4 mm nozzle and the settings in Cura match. I've tested for nozzle clog even though it didn't seem to match the symptoms (nozzle clog would usually be a random, rather than patterned problem) and filament flows quite easily though the nozzle. No junk came out when I did the Atomic method.
We replaced the coupler at the same time as we installed the Olsson block since we had the print head disassembled anyway.
After work today I plan to double check the printer has the latest driver versions and check that all of the motor mounts are tight.
SandervG 1,522
What nozzle have you installed? Are you sure it is the same as the one listed in Cura?
It could be 'plain' under extrusion.
Since you just installed the Olsson Block I don't think your nozzle could be clogged. They should be just new. So an Atomic Method probably won't lead to anything.
Have you ever replaced the PTFE coupler?
