When extruding through a hot nozzle I am finding a significant difference in the measured vs expected extrusion length.
Do you really mean "extrusion length" here?
The esteps value is how many steps (to the extruder motor) are needed to pull one mm of filament into the drive mechanism - it's not about the length of filament coming out of the nozzle.
Unless the filament is being offset (ie: slipping in the drive) in a very predicatable & consistant way, changing esteps may not be the right way to address this problem.
joergen 2
The easiest way during printing is M2210 S100 where the value after S is the amount of extrusion in %
