Yes even experienced users find XT difficult to print with. It not my most favorite material and now prefer nGen.
There seems to be something wrong with your material profiles. You my need to do a firmware update as there was a problem with the original firmware on the + machines that effected the temp.
rumbaughsm 2
Ah, so that definitely explains the conflicting search results. For the record, I'm using Colorfabb XT --http://colorfabb.com/xt-light-blue
In my defense the side of the box says PLA/PHA, I'll take another look when I get back to my home office to see where the confusion originated and I'll edit the original post so as not to mislead other newbies.
On a related note, I found the Ultimaker PLA easy to print with right out of the box. The Colorfabb XT took a lot more tinkering, I'm not sure I would recommend jumping right to it if you're new like me. On the other hand, playing with the settings has been very educational if you don't mind failed print after failed print. I should note I have no quarrels with the Ultimaker 2+. I think it's a great machine and I've been really impressed, every failed print has been user error, of that I'm confident.
I did notice, if you make a custom preset for material, occasionally when warming up before printing, the machine will keep the temperature head at 0 C, and you'll have to manually tune the temperature you wanted. While I'm at it, the temperature overshoots a bit when adjusting, it always corrects itself, but I noticed it can be a problem when printing at 260 C because it will jump to 275 before coming back down and at least on one occasion that caused the machine to read back a temperature error and I had to restart the printer. I found that you can avoid the spikes by slowly increasing the number up by tuning it (i.e. start at 250 and increase in increments of 2)
