I feel that all the odd things in 3d printing are happening to me... :(
I'll reformulate:
This is the Z seam that I wanted to appear in the same place:
This is something that I don't know what to call, so I named it "unwanted seam"
We figgled a lot with the Z seams in different places and depending on the model. If the model has a lot of corners we print with Z seam at random places and if it has smooth surfaces (like that bag handle) we print the Z seam at the same Z coordinate for each layer.
I can't figgure out why that "unwanted seam" is appearing. The weird thing is that when I printed the coat hanger (with the Z seam coordinate placed randomly at each layer) the same effect appeared.
gr5 1,871
The Z seam is usually where the printer pauses briefly and the Z axis moves. Because of this pause you get extra PLA leaking out. You can reduce until the seam is almost invisible through a few techniques (speed/temp). The best thing to do is lower the speed drastically. Try to get your print volume under 2mm^3/sec if you want higher quality. Whatever your speed was for this print, cut it in half. Each time you cut speed in half the seem will get fainter.
In fact I recommend you play with this in the TUNE menu, try 10 different speeds and mark the part with a permanent marker each time you change speeds and keep notes. By the time you finish 30 minutes of printing you will be an expert on Z seams. Also consider lowering the temperature. This will help the z seam also but only if you also slow it down.
