Hi Robert,
Thanks for the links this is exactly what I was looking for. I am assuming the machine is going to be so much better out of the box than my previous one but it doesn't hurt checking a few things before I start.
Also I have Simplify 3D and I have imported the Ultimaker 2 Extended printing profile which I am hoping is going to work well with the + version printer (currently there is no + version profiles in S3D). Are there many people using S3D with Ultimakers? There is not a lot of info in this forum about it so it might be a bit of trial and error.
Thanks, Mike.
IRobertI 502
Generally you shouldn't really have to do anything more than follow the initial setup and get the bed levelled.
One thing I could recommend checking is that the rods are held in place properly. Something the vibrations of shipping can cause the set screws of the pulleys to get loose which can cause the rods can slide slightly. I'm talking about the rods along the top edges of the printer. Just grab them and try to push them back and forth, they shouldn't move (or move very very little, less than a mm).
As for maintenance. A drop of oil on those same rods once in a while (NOT the large rods that guide the bed). Very rarely might you need to put some new lube on the z-screw.
The nozzle can and will get clogged. The "Atomic" is a good way to clear that out.
The glass plate needs to be kept clean and/or have a _thin_ layer of glue on it (supplied with the printer).
You might want to skim through some of the stuff here as well: http://support.3dverkstan.se
