Cura should fix all of this auto-magically. It should either refuse to print one at a time or give a working solution. If the head does hit a print, let us know, because that's a bug.
Thanks! - How can I send you the "Cura"-File that had the problem? To make things worse: Once it worked, twice it didn't using that file...
nallath 1,123
