I've seen that effect when using cheaper filament, I chalked it up to diameter consistency. Swapping to a different brand fixed it for me, your results may vary
This is colorfab red, printed at 40mm/s, all the settings I used before and the print was fine, changing from the original 2 year old extruder I had to the new printed one has helped loads!!! but still a bit rough on the egdes.
dodgrr 27
