For educational purposes, I took the nozzle apart. Doesn't appear to be anything wrong with the PTFE coupler - a bit blackened but the shape is fine. With the coupler out I poured some acetone through the nozzle in case there was residual plastic there.
Put it all back together... exactly the same! Under-extrusion particularly on high speed moves like making the internal grid in prints.
I noticed there is a tuning setting for print speed. I thought printing slower might help, but it seems too little material comes out even when it's going slower.
If it's not the nozzle I figure it must be the feeder motor, unless my filament is bad for some reason.
fbrc8-erin 265
Hi, Stephen,
You could be seeing too much resistance from your bowden tube or PTFE coupler. Both parts are soft and can experience wear and tear, that will cause resistance in the filament's feed path if they're worn out. How much print time is on your machine? You can check this in Maintenance --> Advanced --> Print Time.
You can check bowden tube for damage by sliding the blue clip out sideways, and pushing down on the white collet while pulling up on the tube, at both ends of the machine. If you push a fresh piece of filament through by hand and find a particular point that's resisting you, there could be damage inside the tube. You can also check the feeder end for damage. You can see feeding problems if starts to look too chewed up. I have a photo here showing a good bowden tube and one in need of replacing.
If the coupler is bad, there isn't any way to see that short of taking your printhead apart, but a good rule of thumb on the coupler's lifespan is about 500 print hours with PLA. Over time, due to wear and tear, and heat, the end of the coupler closest to the nozzle widens out and forms a lip, which can create feeding issues.
The other thing that may have changed over the course of your printing, is how tightly wound your filament is on the spool. The closer you get to the end of a spool of filament the tighter the curvature is, making the printer have to work that much harder to fight against it and extrude the same amount of plastic. Are you very near the end of a spool?
stephenbrooks 1
My total printing time is 161h57m. Although some of that was when I experimented with ABS (didn't print much with it though as ultimately fairly unsuccessful), it was mostly PLA.
The end on the nozzle is perfect. The one in the extruder is less perfect but I checked pushing a filament through and there is no excessive resistance from the tube.
No this is a new spool! It actually got a bit worse when I changed to white PLA from grey PLA (although it was also under-extruding with the grey). I tried upping the temperature but that didn't help the extrusion at all and it extruded fine manually.
Somehow the feeder motor is not pushing enough? Should I change the tension setting on the motor? If so, in what direction?
When I re-loaded the material just now, as soon as the filament started to extrude from the nozzle, the feeder motor kept skipping back (about once per second making a "tock" noise).
I just tried a print and although the initial extrusion looked hopeful, it under-extruded during printing (with the same settings that have been fine before), with the internal structure grid not forming solidly.
Edited by GuestLink to post
