I like this idea, can you explain in a little it more detail what you did ?
did you just use the "pause at height"and edited that plug in.
I would really like to see a pause button, that stops the print and moves to the zero position and cools the head,
and able to continue after that.
gr5 1,843
PLA will stick to cold glass but not very well at all. And if you start on hot glass and let it cool the part pops off as glass and PLA have different thermal expansion rates. So if you are going to do this much I recommend you put blue painter's tape on your glass and relevel. Also it's critical that you wipe the blue tape with alcohol to clean off the waxy surface - otherwise parts won't stick well to blue tape either.
