Thanks guys, you were indeed correct.
@IRobertI the initial layer issue I was having was related to something else, I spoke too soon.
Edited by GuestThanks guys, you were indeed correct.
IRobertI 520
The correct way to do it is to set Brim Width to 0mm which is what you did (that's what the old cura does when you choose "None" edit: See below, my bad.).
If you post a picture of the first layer (layer view) it will be easier to figure out what's going on.
Edited by GuestLink to post
nallath 1,123
That's not true. Cura did a skirt when you selected None. This is why we changed the values displayed (eg; Now it actually matches with what is going on).
Setting the brim width to 0mm is the way to go. It is however not recommended to do so (your printer needs a bit of flow to get going, your first layer will be better if you do this).
johank 7
I think the "None" type in old Cura is actually like "Skirt" in Cura 2.1.2.
IRobertI 520
Sorry, my bad. At least I was half right, that's something
