I have the same problem. I also did the same things that Nigel tried.
I've checked the wiring and the z switch. The hardware is all connected and working properly. In fact, when you first turn on the printer after updating the firmware, the table properly activates the z-switch on its way down, and stops. I've re-installed the firmware (for the "+") several times and re-tried. Each time I get the same error.
It seems the new firmware believes the table's travel down should be shorter than it actually is, so it stops before reaching the switch, by a bit over 2 inches.
After contacting the seller of the upgrade kit, I've tried with firmwares from Cura versions 2.1.2 and 15.04.6.
I also tried this when calibrating the table height. Instead of going up to the nozzle, I went up only half-way (roughly 6-7 inches off the bottom). Then, completed the calibration steps although the nozzle was no where near the table. On the table's shorter travel down, it properly triggered the z switch and didn't complain anymore.
So, it seems that there is an internal threshold that is triggered to stop the table when the table comes back down at the end of the calibration. This threshold stops the table far too short of triggering the z-switch, causing the software to emergency stop the table.
Please help! This is very frustrating. Thank you!
FLG 9
Thanks for your reply. The switch trips the circuit straight away swapping them around as you suggest. As soon as I press the microswitch it tricked the head into resetting where it was so I am confident the Z switch itself is working fine.
Putting the switches in their correct positions in the circuit board . . . .
When I turn on the machine and send the build plate down to make the home position it will do this just fine unless I start with the plate towards the top of it's travel. When it starts from higher positions it stops short of tripping the Z switch with the error. It's as though it thinks it should have tripped the switch and times out believing the switch to be faulty, dare I say it.
[/media]
If I turn it off and back on again and send it down it trips the switch and re-sets just fine.
What I don't understand is when I send the plate up from the home position it makes it practically to the top. Sending it down it errors before the bolt gets to the switch.
Repeated tests of the microswitch using a circuit tester at the connector demonstrate the switch is working fine.
I will try installing some older firmware tonight and then install 2.1 again to see it that helps!
Anyone any more ideas!!
00D00B 58
I had a problem like this one before, I downgraded the printer and then it was OK. You can retry to upgrade it after, for me it worked !
Software is now the only possible problem I guess
